ArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-18T21:56:54+01:00 https://brainmodular.org/forums/app.php/feed/topic/1048 2008-10-18T21:56:54+01:00 2008-10-18T21:56:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5735#p5735 <![CDATA[How selecting a specific octave in the sampler ?]]>
If you're basically triggering long files that should play their full length before the next starts, I guess that using the sampler's "stopplay" output should replace the the trigger from sequenced switches, but you would have to add something to trigger the first play. The file grouping and selection bits wouldn't need to be changed much, only (again) what triggers the selection of the next file.
Another solution that also could be useful - at least as long as there aren't any very short files inbetween - would be to use the file length to control the length of the sequenced switch module, and run that one in loop mode. Just enter a switch at step 1.
Rock it, rabbit! (Hey! That even sounded as a real slogan!) ;)
Statistics: Posted by bsork — 18 Oct 2008, 22:56
2008-10-18T00:26:08+01:00 2008-10-18T00:26:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5732#p5732 <![CDATA[How selecting a specific octave in the sampler ?]]>
Yes it's great!! it's working fine, i have tested the version 2, it is quite good for the rythm,very inspiring!!!! But i didn't find how to play longer files??? i mean the full length of a long loop about 24 bars respecting the "num file" ?? (i will test the version 3 now :) ). I really do think that u created a very good tool l!!! (thanks to Mister Senso). I will use it like the core of my livet set, for rythmic and for random long textures...
Rock it math/logic boss !!!!
Statistics: Posted by noise2sine — 18 Oct 2008, 01:26
2008-10-17T23:12:57+01:00 2008-10-17T23:12:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5730#p5730 <![CDATA[How selecting a specific octave in the sampler ?]]>
Just out of curiosity: Do the patch do what you wanted it to?
Statistics: Posted by bsork — 18 Oct 2008, 00:12
2008-10-17T08:08:03+01:00 2008-10-17T08:08:03+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5723#p5723 <![CDATA[How selecting a specific octave in the sampler ?]]>
many thanks!!!!
Statistics: Posted by noise2sine — 17 Oct 2008, 09:08
2008-10-17T00:38:57+01:00 2008-10-17T00:38:57+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5720#p5720 <![CDATA[How selecting a specific octave in the sampler ?]]> http://www.sensomusic.com/forums/viewto ... 5719#p5719
I was thinking of adding a more typical "multi-sample" behaviour as well, as that was what I originally thought you were after, but it's getting late.
Statistics: Posted by bsork — 17 Oct 2008, 01:38
2008-10-16T09:32:21+01:00 2008-10-16T09:32:21+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5699#p5699 <![CDATA[How selecting a specific octave in the sampler ?]]>
Statistics: Posted by noise2sine — 16 Oct 2008, 10:32
2008-10-16T09:19:36+01:00 2008-10-16T09:19:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5698#p5698 <![CDATA[How selecting a specific octave in the sampler ?]]> Statistics: Posted by bsork — 16 Oct 2008, 10:19
2008-10-16T08:32:52+01:00 2008-10-16T08:32:52+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5697#p5697 <![CDATA[How selecting a specific octave in the sampler ?]]>
The math needed here is fortunately of the simple kind, so I'm sure you're going to fix it.
Well, i don't get the logic even it's quite simple,I tried for 2 hours yesterday but nothing good happen ! So if u have time to fix that patch, i would be very gratefull and then i will study it in order to improve my perception of math module ! because it's a little bit of frustration because i don't have the fundamental so i can't really progress and i really want to.
Statistics: Posted by noise2sine — 16 Oct 2008, 09:32
2008-10-15T13:56:46+01:00 2008-10-15T13:56:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5685#p5685 <![CDATA[How selecting a specific octave in the sampler ?]]> Statistics: Posted by bsork — 15 Oct 2008, 14:56
2008-10-15T12:28:10+01:00 2008-10-15T12:28:10+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5684#p5684 <![CDATA[How selecting a specific octave in the sampler ?]]>
If I have understood this time around..: You want the sampler to switch files automatically exactly as the built in next/previous/random, but with groups of samples instead of the whole list(?). :
Yes that's exactly what i need ! But unfortunatly math is esoteric to me !!! ( i wish i could do a Usine Workshop one day :)
But i will try then, following yr instruction.
Will it be possible to recall that with presets or stored in the conductor ?
(you helped me so much so i will send you for xmas a jar of honey from the south of France !!!)
Statistics: Posted by noise2sine — 15 Oct 2008, 13:28
2008-10-15T11:06:41+01:00 2008-10-15T11:06:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5683#p5683 <![CDATA[How selecting a specific octave in the sampler ?]]>
(I just had a look at the "Counter Simple with Max" sub-patch, and seems to have been broken as there's no max, while the "(down)" version looks ok. I've notified Olivier.)
(...and I'm afraid it's not my drawing - just something I found somewhere and messed up a little... Bjørn is Norwegian for "bear", so that's my excuse for using that avatar.) :P
Statistics: Posted by bsork — 15 Oct 2008, 12:06
2008-10-15T10:32:49+01:00 2008-10-15T10:32:49+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5682#p5682 <![CDATA[How selecting a specific octave in the sampler ?]]>
Perhaps can you use random modules linked to the file inlet of the sampler. Choose min and max in the random module according to the preset of sample you want...
Thank you ethnix for yr idea, i will try that!!
but i'm curious to know if my suggestion with the faders can work !
Statistics: Posted by noise2sine — 15 Oct 2008, 11:32
2008-10-15T10:29:40+01:00 2008-10-15T10:29:40+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5681#p5681 <![CDATA[How selecting a specific octave in the sampler ?]]> So i should be able to have 127 samples in the same sampler with the freedom of choosing which groups i want to use
Hope i'm clear :) , and yr drawing is very nice!!!
Statistics: Posted by noise2sine — 15 Oct 2008, 11:29
2008-10-15T10:11:54+01:00 2008-10-15T10:11:54+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5680#p5680 <![CDATA[How selecting a specific octave in the sampler ?]]> Statistics: Posted by ethnix73 — 15 Oct 2008, 11:11
2008-10-15T10:07:55+01:00 2008-10-15T10:07:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5678#p5678 <![CDATA[How selecting a specific octave in the sampler ?]]>
"just a rabbit"? At least you look like a living thing - me, I'm just a (bad) drawing! ;)
Statistics: Posted by bsork — 15 Oct 2008, 11:07
2008-10-15T09:37:36+01:00 2008-10-15T09:37:36+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5676#p5676 <![CDATA[How selecting a specific octave in the sampler ?]]>
Any advice are welcome for setting up that kind of sampler !!!
Statistics: Posted by noise2sine — 15 Oct 2008, 10:37
2008-10-15T08:43:33+01:00 2008-10-15T08:43:33+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5671#p5671 <![CDATA[How selecting a specific octave in the sampler ?]]>
Either that, or use more than one sampler...
Statistics: Posted by bsork — 15 Oct 2008, 09:43
2008-10-15T07:58:48+01:00 2008-10-15T07:58:48+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5670#p5670 <![CDATA[How selecting a specific octave in the sampler ?]]>
i think i wasn't clear, i 'm giving an example : i'm using 24 samples in a Usine sampler and i want the sampler only play the first 12 samples in any type of readind mode (next,previous,random) and this stored as a preset, and then a second preset for the last 12 and so on....
So the relation with sequencer is : i have full tracks running in the sequencer and this sampler is used for adding some improvisation feel or adding rythm to a specific track.
Thanks you !
Statistics: Posted by noise2sine — 15 Oct 2008, 08:58
2008-10-14T23:09:34+01:00 2008-10-14T23:09:34+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5658#p5658 <![CDATA[How selecting a specific octave in the sampler ?]]> Statistics: Posted by ethnix73 — 15 Oct 2008, 00:09
2008-10-14T21:50:11+01:00 2008-10-14T21:50:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5656#p5656 <![CDATA[How selecting a specific octave in the sampler ?]]> Statistics: Posted by bsork — 14 Oct 2008, 22:50
2008-10-14T18:20:15+01:00 2008-10-14T18:20:15+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5650#p5650 <![CDATA[How selecting a specific octave in the sampler ?]]>
If so, you could use multiple midi split script.
Statistics: Posted by ethnix73 — 14 Oct 2008, 19:20
2008-10-14T14:36:46+01:00 2008-10-14T14:36:46+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5647#p5647 <![CDATA[How selecting a specific octave in the sampler ?]]>
Statistics: Posted by noise2sine — 14 Oct 2008, 15:36
2008-10-10T10:40:22+01:00 2008-10-10T10:40:22+01:00 https://brainmodular.org/forums/viewtopic.php?t=1048&p=5583#p5583 <![CDATA[How selecting a specific octave in the sampler ?]]>
i have a big list of samples in a sampler, in the grid mode and this list correspond to specific tracks organised in the sequencer.My idea is to be able to choose a specific octave for each track in order to use for example the random mode in the sampler and staying "framed" with the corresponding track ?
I have the impression that i have already seen a sampler like that in the library but i can't find it anymore!!!
Thank you!!
Statistics: Posted by noise2sine — 10 Oct 2008, 11:40
many thanks!!!!
Thanks you !
Thank you!!
