ArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-03T12:31:51+01:00 https://brainmodular.org/forums/app.php/feed/topic/1028 2008-10-03T12:31:51+01:00 2008-10-03T12:31:51+01:00 https://brainmodular.org/forums/viewtopic.php?t=1028&p=5515#p5515 <![CDATA[Program changes and MIDI channel]]> Happy to hear this problem will be solved in next version, and yes nay-seven, you're perfectly clear, thanks :)
Statistics: Posted by La Tenaille — 03 Oct 2008, 13:31
2008-10-02T21:58:45+01:00 2008-10-02T21:58:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1028&p=5511#p5511 <![CDATA[Program changes and MIDI channel]]> the pb is now solved in the v4 (next week)
Statistics: Posted by senso — 02 Oct 2008, 22:58
2008-10-02T19:17:11+01:00 2008-10-02T19:17:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=1028&p=5509#p5509 <![CDATA[Program changes and MIDI channel]]> for note on /off , control change , aftertouch , the module "midi out send the correct canal
for program change it's always canal 1...bug
about the second question , , yes , the midi out module is " your last choice "and at the end of the midi flow so work in this case as a kind of master
hope i'm clear....
Statistics: Posted by nay-seven — 02 Oct 2008, 20:17
2008-10-02T13:52:02+01:00 2008-10-02T13:52:02+01:00 https://brainmodular.org/forums/viewtopic.php?t=1028&p=5498#p5498 <![CDATA[Program changes and MIDI channel]]> Something I don't understand: I've patched a midi create to a midi out on channel 3.
> If I create Control Changes, everything's ok, the message is received by my external device on ch3.
> If I send program changes (I just change the type of message in the midi create combo) it doesn't work, the message is sent on channel 1 regardless of my tuning.
An idea?
PS: I still don't understand the interaction between the ch. number carried inside the midi message and the ch. number indicated in the midi out combo. For example if I create "CC 12 127 c:1" and send it to MIDI out on ch. 3, the "c:1" is ignored?
Statistics: Posted by La Tenaille — 02 Oct 2008, 14:52
hope i'm clear....
An idea?
