ArrayArrayArrayArrayArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-20T14:53:09+01:00 https://brainmodular.org/forums/app.php/feed/topic/1024 2008-10-20T14:53:09+01:00 2008-10-20T14:53:09+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5767#p5767 <![CDATA[Recording the bass liner velocity ?]]> Statistics: Posted by noise2sine — 20 Oct 2008, 15:53
2008-10-20T13:24:11+01:00 2008-10-20T13:24:11+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5760#p5760 <![CDATA[Recording the bass liner velocity ?]]> Statistics: Posted by bsork — 20 Oct 2008, 14:24
2008-10-20T12:54:08+01:00 2008-10-20T12:54:08+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5759#p5759 <![CDATA[Recording the bass liner velocity ?]]>
you should alter the output of the "velocity" sequenced steps module to something like min=-80, max=12 (or a smaller interval if you prefer).
I think i can start hoping that i will enventually understand!! so how can I manage to have negative values from the velocity step module output ???? oh my little rabbit head is hurting!!!
Statistics: Posted by noise2sine — 20 Oct 2008, 13:54
2008-10-20T11:56:23+01:00 2008-10-20T11:56:23+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5758#p5758 <![CDATA[Recording the bass liner velocity ?]]>
If you keep the connection to the MIDI transform, you should alter the output of the "velocity" sequenced steps module to something like min=-80, max=12 (or a smaller interval if you prefer). As it is, it outputs only values between 0 and 1 which doesn't really amount to much variation... You should also remove the gain fader, or else the steps and the fader get added at the gain input, or - if you want to keep the fader - change the min/max values to a smaller interval so it's useable for adding or subtracting values to the steps' output.
Statistics: Posted by bsork — 20 Oct 2008, 12:56
2008-10-20T09:52:18+01:00 2008-10-20T09:52:18+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5753#p5753 <![CDATA[Recording the bass liner velocity ?]]>
you could connect the velocity to "gain" on the existing MIDI Transform module in the patch. Either way you have to mess around with the min/max value of the velocity module to get something useful.
Obviously i didn't manage to make it work :). And once again i'm soliciting some help from the north!!!
So i'm using the patch "bass liner+velocity" in order to create a groove box using Native Instruments Battery. The construction of the bass liner is perfect for what i need to do, except the fact that i can't have for now midi velocities values.
When u say "connect velocity to "gain" i understand obviously where i have to connect it but what i don't know, is what you call "velocity" is it the module "step" in the bass liner patch ?? i tried to connect this out to the gain of the Midi Transform and adding a piano roll to the out of the midi transform and while recording, there is no velocity changes !!!!!
When u say messing around with min/max what does it mean ??? because i have changed some values and nothing changed!!
Thanks in advance...
Statistics: Posted by noise2sine — 20 Oct 2008, 10:52
2008-10-01T06:50:38+01:00 2008-10-01T06:50:38+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5480#p5480 <![CDATA[Recording the bass liner velocity ?]]>
You either have to use a Create MIDI Message module to combine the note/pitch output and the velocity output into a single MIDI message, or you could connect the velocity to "gain" on the existing MIDI Transform module in the patch. Either way you have to mess around with the min/max value of the velocity module to get something useful.
Statistics: Posted by bsork — 01 Oct 2008, 07:50
2008-09-30T10:46:01+01:00 2008-09-30T10:46:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5474#p5474 <![CDATA[Recording the bass liner velocity ?]]>
thank u :)
Statistics: Posted by noise2sine — 30 Sep 2008, 11:46
2008-09-30T10:27:07+01:00 2008-09-30T10:27:07+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5473#p5473 <![CDATA[Recording the bass liner velocity ?]]> actually how do you record the bass line? do you transform midi input to array?
Statistics: Posted by senso — 30 Sep 2008, 11:27
2008-09-30T08:22:17+01:00 2008-09-30T08:22:17+01:00 https://brainmodular.org/forums/viewtopic.php?t=1024&p=5468#p5468 <![CDATA[Recording the bass liner velocity ?]]>
Recording the bass liner is quite fun , but unfortunatly when i 'm recording the note pattern, i noticed that i wasn't recording his velocity. i have looked inside the patch, and it seem that velocity datas are directed only towards the audio output.
how can i record the velocity ??
thank u :)
Statistics: Posted by noise2sine — 30 Sep 2008, 09:22
thank u :)
thank u :)
