ArrayArrayArrayArrayArray BrainModular BrainModular Users Forum 2008-10-02T13:33:45+01:00 https://brainmodular.org/forums/app.php/feed/topic/1021 2008-10-02T13:33:45+01:00 2008-10-02T13:33:45+01:00 https://brainmodular.org/forums/viewtopic.php?t=1021&p=5497#p5497 <![CDATA[How can I send a continuous CC midi message?]]> Sorry but I made a mistake reading the Voicelive manual. In fact if I want to hold, I just need to change the message code 2 to 127 and it works as long as the message isn't changed.
Thanks for your help, and sorry again for the time you've lost ;)
Statistics: Posted by La Tenaille — 02 Oct 2008, 14:33
2008-09-25T07:44:55+01:00 2008-09-25T07:44:55+01:00 https://brainmodular.org/forums/viewtopic.php?t=1021&p=5432#p5432 <![CDATA[How can I send a continuous CC midi message?]]> Statistics: Posted by bsork — 25 Sep 2008, 08:44
2008-09-24T23:09:41+01:00 2008-09-24T23:09:41+01:00 https://brainmodular.org/forums/viewtopic.php?t=1021&p=5430#p5430 <![CDATA[How can I send a continuous CC midi message?]]> code1= 119
code2 =100
and a switch ( on ) on create...?
seems to work in the midi monitor....then apply a midi learn to this switch...?
Statistics: Posted by nay-seven — 25 Sep 2008, 00:09
2008-09-24T17:25:01+01:00 2008-09-24T17:25:01+01:00 https://brainmodular.org/forums/viewtopic.php?t=1021&p=5422#p5422 <![CDATA[How can I send a continuous CC midi message?]]>
Have you tried connecting something that generates data all the time? For instance an LFO connected to a HasChanged connected to the create input of MidiCreate. Just an idea...
Statistics: Posted by bsork — 24 Sep 2008, 18:25
2008-09-24T15:51:24+01:00 2008-09-24T15:51:24+01:00 https://brainmodular.org/forums/viewtopic.php?t=1021&p=5421#p5421 <![CDATA[How can I send a continuous CC midi message?]]> I'm patching usine to remote my TC Electronic Voicelive.
Simple CC sends work perfectly, but a specific function of the Voicelive, called "Harmony Hold", needs to receive a continuous CC to work.
In other words, as long as I hold my pedal in momentary mode, I'd like the midi led of the Voicelive to remain lit, not just a flash.
Do you have a solution?
Thanks for your help ;)
Statistics: Posted by La Tenaille — 24 Sep 2008, 16:51
code2 =100
