thank u so much for yr help!!! (my girlfriend is happy too, i stopped walking all around the house, talking alone
Statistics: Posted by noise2sine — 30 Sep 2008, 23:00
]]>2008-09-30T17:03:42+01:002008-09-30T17:03:42+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5478#p5478It's a small bug (solved in the the 4.0) You can solve it easily with insert a 'Math/Round' between the 'UserCurve' module and the 'PianoRoll'.
]]>2008-09-30T14:50:02+01:002008-09-30T14:50:02+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5477#p5477 i plugged a simple list box to the num file inlet of the piano roll and i have no trouble for changing loops manually. if i plug a user curve to that list box, the first value is working and only the first, the second value change the loop number but produce no sound!!!!!
i start thinking that User curves are related to the Twilight Zone !!
Statistics: Posted by noise2sine — 30 Sep 2008, 15:50
]]>2008-09-30T12:43:17+01:002008-09-30T12:43:17+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5476#p5476 well the problem seems to be the user curves. if for example i choose user curve value 1 for loop 1 and user curve value 2 for loop 2. i can notice that in the piano roll for the first case it's fine and as soon as the value change to 2 the red (tete de lecture) in the piano roll is going beserk and loosing sound and when is moving to value 1it's working, the sound is back and fine !!!!!!
i'm lost and with a performance in 3 days
Statistics: Posted by noise2sine — 30 Sep 2008, 13:43
- i have weird sound (like something broken) - i don't see the loop changing in the piano it's stay frozen on the first loop, not respecting the user curves indication - the sequencer is not accurate on the beat .
I have tried your patch but I cant reproduce the behavior you describe, on the 3.68f or the new 4.0. (a piano roll in the sequencer --> midi bus and midi bus ----> vsti) But some vst can have unusual responses to CC did you try to use a midi filter to bloc the CC before the vsti?
It's strange because User curves to change Num file is working here...
ok, so i'm using the last version of Usine, the Pro version :
on track 1, i have a vsti as an insert patch with a "receive from midi bus" . On the sequencer i have a patch made only with a piano roll and a "send to midi bus " So at that point it's working. As soon as i create a User curve on the piano roll "num file" it's the begining of the end!!! i'm making a 8 bars loop, the first four bars : midi loop Number 1 and midi loop 2 for bars 5 to 9 . When i 'm pressing play :
When i delete the user curve i can hear sound and everything is working ???
I tried to use the seq midi module and i can see the loop responding to the user curves but when the loop is changing i'm losing sound, and when it start again on the first loop, i can hear sound and no sound the second loop.
So when u tell me it's working for u ? is yr configuration different from mine ? because i tested it on the sequencer mode and maybe u tested in the grid mode ???
Statistics: Posted by noise2sine — 30 Sep 2008, 10:25
Another question : in the sequencer mode i put some markers in order to have four differents loops and and i'm using the arrow in the dash board in order to change loops, this is working fine but when i want to move from loops 4 to loop 3,the cursor stayed blocked on the last loop, if i want to go backward i have to stop the sequencer???
in seq mode there are the 'continue' '<|' and '|>' controls. pressing '<|' returns to the last loop. further you can access the loop markers directly... a problem I had and indicated once: if you set one of the seq controls quantize to cycle or bar, usine does sometimes not respond, and it hangs on the 'quantizing' message screen until you remove the quantization limitation.
Statistics: Posted by amiga909 — 29 Sep 2008, 22:35
]]>2008-09-29T12:08:00+01:002008-09-29T12:08:00+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5454#p5454so maybe it's a bug, i will try again
Statistics: Posted by noise2sine — 29 Sep 2008, 13:08
]]>2008-09-29T11:57:12+01:002008-09-29T11:57:12+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5453#p5453Statistics: Posted by ethnix73 — 29 Sep 2008, 12:57
You could connect one of the list box to the num file inlet of the piano roll. It should work...
Yes it 's working but not the way i want!! first:
1) is it normal that the user curves don't work on the Num file of the piano roll ? (because it's the easiest way!!!)
2) ethnix advice don't really answer my need because i wanted to change the different midi loops in the piano roll according some defined bars position and the list box is supposed to be controlled by the conductor that mean that i have to activitate it and i don't want that, i would prefer automating that section
3) i'm giving an example : in the same piano roll : bar 1 to 8 midi loop 1 ; bar 9 to 17 midi loop 2
any solution ??
Statistics: Posted by noise2sine — 29 Sep 2008, 10:25
]]>2008-09-24T12:37:39+01:002008-09-24T12:37:39+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5412#p5412 Yes i will try yr suggestion too, it's very good to have different choice than being stuck!!!
Thanks again l
Statistics: Posted by noise2sine — 24 Sep 2008, 13:37
]]>2008-09-24T10:17:46+01:002008-09-24T10:17:46+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5404#p5404 You could connect one of the list box to the num file inlet of the piano roll. It should work...
Statistics: Posted by ethnix73 — 24 Sep 2008, 11:17
]]>2008-09-24T10:07:07+01:002008-09-24T10:07:07+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5403#p5403 So great it's working the way i wanted!! thank u Bsork for yr help and patience
Statistics: Posted by noise2sine — 24 Sep 2008, 11:07
]]>2008-09-24T09:54:07+01:002008-09-24T09:54:07+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5402#p5402So i reproduce the same patch, i got now no error message but the user curve has no effect on the "num file" of the piano rolli can see no change ? Can the user curve has an influence on the "num file" in order to simply change the loop in the piano roll ?
Statistics: Posted by noise2sine — 24 Sep 2008, 10:54
]]>2008-09-24T09:26:45+01:002008-09-24T09:26:45+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5401#p5401Statistics: Posted by bsork — 24 Sep 2008, 10:26
]]>2008-09-24T09:16:01+01:002008-09-24T09:16:01+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5400#p5400 - an insert patch with the vsi with "get from midi bus" - on the same track a midi file with a "send to midi bus" module
it's working fine, but it's just one pattern running, so i copied that patch and connect a user curve to the 'file num" inlet in order to select the second loop present in the piano roll and i get a message error "Interanl in BufferSwitch Time info"
What's wrong there ?
Statistics: Posted by noise2sine — 24 Sep 2008, 10:16
]]>2008-09-24T08:40:11+01:002008-09-24T08:40:11+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5399#p5399Statistics: Posted by bsork — 24 Sep 2008, 09:40
]]>2008-09-24T08:03:15+01:002008-09-24T08:03:15+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5395#p5395 Am i wrong ?
Statistics: Posted by noise2sine — 24 Sep 2008, 09:03
]]>2008-09-23T14:37:21+01:002008-09-23T14:37:21+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5386#p5386 Don't have time to look into your other question now, anyone else has a solution?
]]>2008-09-23T13:57:27+01:002008-09-23T13:57:27+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5385#p5385 i have followed the advice from nay seven to throw away Ableton Live in the recycle bin and keeping Usine in the Main Role. That decision is a mature one and at the same time many question need to be asked So here 's the first one:
When i'm dragging a midi file in a sequencer track, i don't only have a midi file but a sampler as well. Is it possible to create an insert patch with a synth in order to read different midi files on the same track ?
thank u!!!
Statistics: Posted by noise2sine — 23 Sep 2008, 14:57
]]>2008-09-29T09:25:54+01:002008-09-29T09:25:54+01:00https://brainmodular.org/forums/viewtopic.php?t=1012&p=5452#p5452
Hi noise2sine,
any solution ??
Thanks again l
thank u!!!
