[EDIT:] I just got another idea for a simple solution that doesn't need complex patching if you want to filter everything but NoteOffs: Use a MIDI Filter module instead of a Stop Event Flow and between the "mute" switch and the filter input use a A*B where B=3. That way, -No filter- is chosen when the switch is off and NOTE OFF when the switch is on.
(Just for the record: The MIDI Filter module filters out everything except what's selected - some other filters in other programs and hardware boxes I've encountered do the opposite.)
This is of course a very simple solution, and may lead to problems with stuck notes if the NoteOffs haven't been sent before muting the MIDI stream.
not necessarily - you could trigger the all notes off script with the same switch solving the stuck note problem couldn't you?
Statistics: Posted by Clearscreen — 23 Sep 2008, 02:42
]]>2008-09-22T23:54:41+01:002008-09-22T23:54:41+01:00https://brainmodular.org/forums/viewtopic.php?t=1011&p=5382#p5382thank you very much for the replies!
Statistics: Posted by Danilo_Bovi — 23 Sep 2008, 00:54
]]>2008-09-22T09:03:50+01:002008-09-22T09:03:50+01:00https://brainmodular.org/forums/viewtopic.php?t=1011&p=5381#p5381Statistics: Posted by grego mondo — 22 Sep 2008, 10:03
2008-09-22T06:30:37+01:002008-09-22T06:30:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1011&p=5380#p5380 This is of course a very simple solution, and may lead to problems with stuck notes if the NoteOffs haven't been sent before muting the MIDI stream.
]]>2008-09-21T19:07:35+01:002008-09-21T19:07:35+01:00https://brainmodular.org/forums/viewtopic.php?t=1011&p=5377#p5377i'm very new to usine and i have 2 (stupid ) questions. i'm doing a sort of "midi-groovebox" to control my hardware synths. there is a way to make a midi-mute switcher in usine? the second question is: there is a way to exclude some values from a fader control (for example i wanna use only multiple of 2)? thank you in advice, excuse my bad english and have a nice day!
edit: i solved the second problem with the math modules (it was very simple to do..sometimes i'm very distracted)
Statistics: Posted by Danilo_Bovi — 21 Sep 2008, 20:07
]]>2008-09-22T06:30:37+01:002008-09-22T06:30:37+01:00https://brainmodular.org/forums/viewtopic.php?t=1011&p=5380#p5380 This is of course a very simple solution, and may lead to problems with stuck notes if the NoteOffs haven't been sent before muting the MIDI stream.
