ArrayArrayArrayArray
BrainModularBrainModular Users Forum2008-09-21T18:28:48+01:00https://brainmodular.org/forums/app.php/feed/topic/10102008-09-21T18:28:48+01:002008-09-21T18:28:48+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5376#p5376i must try it.
Statistics: Posted by Danilo_Bovi — 21 Sep 2008, 19:28
]]>2008-09-21T15:34:51+01:002008-09-21T15:34:51+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5375#p5375Ingenious interface - so simple to use and to get complex textures.
What would make it more convenient would be a VST version.
]]>2008-09-20T12:35:25+01:002008-09-20T12:35:25+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5369#p5369Statistics: Posted by noise2sine — 20 Sep 2008, 13:35
2008-09-20T11:03:05+01:002008-09-20T11:03:05+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5368#p5368 " nodal music sequencer.
It’s pretty simple: Each node represents an event, and a connection from one node to the next triggers the next event after a certain number of tics. Nodes send MIDI note messages and/or MIDI controller change messages when triggered. Connecting nodes in a circuit lets you start a repeating pattern when one of the nodes is triggered.
A node can change its pitch and controller values based on its position on the screen. When a node is triggered, it performs some physical action: either repelling or attracting other nearby nodes, or nudging itself in a random direction. The physical interaction between nodes allows you to construct complex, rhythmic melodies and effects without having to draw filter envelopes or touch a traditional sequencer. "
Statistics: Posted by nay-seven — 20 Sep 2008, 12:03
]]>BrainModularBrainModular Users Forum2008-09-21T18:28:48+01:00https://brainmodular.org/forums/app.php/feed/topic/10102008-09-21T18:28:48+01:002008-09-21T18:28:48+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5376#p5376i must try it.
]]>2008-09-20T11:03:05+01:002008-09-20T11:03:05+01:00https://brainmodular.org/forums/viewtopic.php?t=1010&p=5368#p5368 " nodal music sequencer.
